need some amp instalation help
  • Thread starter <baller540>
  • Start date
  • Replies 1
  • Views 2K
  • 1
<baller540>
Guest
I am hooking up two memphis 500 class d amps to in trunk. Someone told me not to hook up capacitators to them because they are class d, and they have caps built into them. Is this true? The local car audio store said to hook up a seperate battery to them in the trunk. How do I hook this up to the battery in the front of my car? What gauge wire do I use? And will my alternator power both of these(it is a stock alt. but it is only 2 years old)? I have a 900 watt cold cranking amp in front right now. Can I run both amps off this? Thank you for any ifno at all if you can help me.
11
660
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
964
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Guest
Matt
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
