Need some diagnostic advice
  • 2
sbelew
I have a Massive Audio NX5 amp, and 2 JBL GTO804's. Also using a relay to turn amp on and power a fan. Its worked fine for years but lately, when I turn the HU on, the 4 channels come on and work fine, but the subs do not. I have to turn the volume up quite a bit to get the subs to start working. Can anyone give me some ideas where to start looking for problems?
Thanks
Steve
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
195
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
147
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
504
sbelew
sbelew
New Port Richey, FL
the727kid
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
