Need some help,amp and box won't stop sliding around in my trunk
TheCandyMan
MI
I have a 2000 Grand Prix GT and i got 1 12in L7 in a ported box and i will soon have a amp within' the next 24hours. The other amp i had hooked up tho kept sliding all over the dang place and my wires kept getting ripped out. What would you reccomend i use to keep it still and in one spot? ANYTHING that will not create more rattling when i'm bumpin will do. HELPPP??
BOLT IT DOWN! if you get in a wreck that thing is coming right through the seat back. anybody see the fifth gear episode where they did this? even a tool box in the back went off like a grenade in a wreck, destroyed the seat back and sprayed tools everywhere. that speaker box weighs a lot more then a toolbox. most interesting was where it hit the drivers seat and mangled it. remember the laws of physics.
yeah i had 2 10in solox's in 1inch thick double ported box and got hit by an old lady from the back getting on the expressway and my box literly BROKE THREW my backseat like barely. If the box was a little lighter it probably would of went all the way threw and fuuuuucked me allll up.
I mounted my amp to my box, slid the box all the way against the seat, and cut a board to fit up against the box to the back of the trunk. Doesn't budge.
Hello Everybody, Due to an incorrect install from a local stereo shop one the channels of my Alpine PDX-F4 is no longer working. I was told...
984
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
TheCandyMan
TheCandyMan
MI
craigzter
