Need some help with wiring and amp selection
  • 2
Higgssauce
I have a two door 72 impala...Ok I have questions on amps to get and proper way to hook the wires up on my mids and highs. I'm trying to keep it to two amps or one if possible. I will have 4 6" selenium 6w4p in each door 100/200 watt 8 ohm each. Then in dash I have 2 6" selenium 6w4p also with two db drive 5ptw 1" 150/300 watt 8 ohm. And last in console I have 4 of the db drive 5ptw 1"... I would like to run both doors off one amp and the dash and console off one amp.... My first question is which amps to use that won't cost me a **** load. Second If possible, a sorta detailed wiring diagram of speaker to speaker and then to amp. I also will be running an eq up front.
Also please keep ******** out i already have the speakers, and dont need to know what you run in your car or what i should change mine to.... I just need answers, thanks in advanced, sorry people always want to add their 2 cents....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
a 2 channel for the door mids ,+ to + and - to - on each door and mid the to the amp if its 2 ohm stable .and a 4 channel for the dash and console ,the front channels for the mids at 8 ohms each and the tweets at 3 ohms or wire up like the doors for the dash and console 5ptw 1"
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
Higgssauce
Higgssauce
Tampa, fl
mylows10
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
