Need some (hopefully local) help to guide me through this 4-ch amp/HU installation..
  • 1
gmarv00
4
SoFla
So a few years back I bought a pair of PPI 356cs thinking I could fit a square peg in a round hole with replacing the front speakers (car's a 2012 mustang, factory garbage is 6x8 but the PPI is 6.5").
I was able to barely fit them in the doors along with the x-overs. I have a
PPI 4-channel amp ready to go as well as a pioneer DEH80PRS + harness + dash kit.. but after botching the front speakers I'm not sure I trust myself anymore //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
If anyone's around SoFla (boca/delray/ftl/etc) that could lend a hand PM me, I'd obviously compensate :p
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
173
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
127
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
471
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
363
gmarv00
gmarv00
SoFla
gmarv00
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
