Need some input from the JDM bro's.
Opinions
  • 1
    Votes: 0 0.0%
  • 2.
    Votes: 0 0.0%
  • 4
    Votes: 0 0.0%
  • 5
    Votes: 0 0.0%
  • Total voters
    5
silvercookie
WRX
7,703
Queens, NY
So on september 15th my motor went. Cracked piston in cylinder 3.
Since then i haven't been able to decide what the **** i want to do.
So many options, such little $.
Basically here is the list of options i have.
1. Used ej205 bare long block and just swap all my stuff over.
2. Build my current block with forge rods and pistons, some head work.
3. Get a used 2.5l sti shortblock, slap my heads on it for a hybrid setup.
4 .Buy a brand new 2.5l sti shortblock from subaru and put my heads on it for a hybrid setup.
5 .Try to find a used sti longlock, delete avcs and swap all my stuff over.
6. Pick up a JDM ej207 from a V7 sti and swap the entire motor in.
All in all, everything else will be re-used.
VF-48
Tial 38mm wastegate
Grimmspeed wastegate up-pipe.
Grimmspeed boost control solenoid.
stock manifold (most likely will upgrade)
DeatschWerks 750cc injectors.
Full catless turbo back.
Currently a injen shortram but i am going to get something else.
will also be upgrading to at minimum STi TMIC.
Walbro 255 fuel pump.
I will most likely be adding a better than stock inlet also.
Vote/post opinions.
I remember reading in scc a long time ago about certain cylinders starving for fuel on boxer engines
Not starving for fuel, starving for air.
The intake manifold layout is kinda dumb. That is why alot of people that go for big power end up using 2.5 non-turbo intake manifolds.
they are more equally setup.
id love to do a ej257 swap turbo. promising as heck. but a ej207 would be the cheapest.
Serious question, do you know anything about subaru's?
Not starving for fuel, starving for air.The intake manifold layout is kinda dumb. That is why alot of people that go for big power end up using 2.5 non-turbo intake manifolds.
yeah... although i drive a legacy.. ive been doing alot of reading and what not about swaps. i drive a ej251. and am going to swap in rods and pistons out of a ej257. run an ej257 head gasket and run a small boost setup
however swapping up to the ej257 now gives you more displacement and torque.
but you also want to know why you cracked your piston. detonation? too lean, over heated? etc.
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
276
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
262
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
635
11
519
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
silvercookie
WRX
silvercookie
Queens, NY
silvercookie
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
