Need to clean out my car.
Tupolev
Mountaintop Stainer
Just bought a bank repo and there's blood from the horn to the passenger side door. I can clean off the plastic no problem. I just need tips on cleaning out the blood from the seats and the floor panels. Replacing the seats is not a viable option as I've sunk some money into replacing the caved in door.
get a steam cleaner try with that and oxyclean it will remove some of the blood depending on how long its been in the fabric... but blood is really hard to get out of fabric period... best thing to do is find a junk yard or something and replace everything cheap that way
It's worth it, 2003 PONTIAC AZTEK, 160K on the ODO. Minor damage.
102.7 is "The Blaze", it's a rap station. wtf
Blood doesn't bug me, the only think I wish it didn't have was the "Vietnam Veteran" sticker on the back.
this sounds familliar
I believe that the LC2i has a fixed subsonic filter at 33hz, that will affect the low end too. THe LCi2 pro has a set filter at 22 hz, better...
37
178
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
132
474
Tupolev
Mountaintop Stainer
Tupolev
Under the bridge, seriously.
foomanchu
    May 18, 2024
    May 18, 2024
