?? Need to know about the quality of these 2 amps ??
  • 2
BlancaLoca
I have 2 12' Pheonix Gold Radial SD competition subs. I need a 1000 watt + amp to push them. I recently bought a powerzone Crunch 1500.1 amp but am not sure if this will provide the good quality I am looking for. Also have had my eye on an O2/Q2 3000 watt amp but am not sure if this has good quality either.. also not sure if this will be too much to push these 2 12's. Not sure what the RMS rating is fo the subs but I was told I need a 1000 watt amp or better.
Also does anyone have any suggestions for a high quality amp that will push these subs and not blow a whole in my pocket...
Thanks for your help
Blane
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
157
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
462
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
356
BlancaLoca
BlancaLoca
Largo, FL
bunkrd you
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
