NEED TO KNOW! Quick wiring question! Help!
  • 2
jackattack
1989 honda crx
connecting kenwood kdc-mp245
have to hardwire into car, no harness
have the speaker and ground connections figured out.
I need to know which connection goes where: connect the (Battery/YELLOW) wire and (Ignition/RED) wire INTO either the (RED/YELLOW Main stereo supply/radio switched 12v+) or the (WHITE/GREEN Constant power 12v+).
. I need to know which connection goes where: connect the (Battery/YELLOW) wire and (Ignition/RED) wire INTO either the (RED/YELLOW Main stereo supply/radio switched 12v+) or the (WHITE/GREEN Constant power 12v+).
did you even think for more than 5 seconds about this question?
connect the (Battery/YELLOW) wire (WHITE/GREEN Constant power 12v+).
(Ignition/RED) (RED/YELLOW Main stereo supply/radio switched 12v+)
wow that was really rude.
hope you feel good about yourself.
thanks for you response, assanine though it may be.
after a little more research i solved the problem, and came up with the same solution. thanks for taking the time to be a nice guy, and a dick all at the same time.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
213
Thanks for your input! I did some research and wanted to share what I found for anyone else in a similar situation. It turns out that the Honda...
179
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
510
jackattack
jackattack
the couve
jackattack
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
