Needing some help on an install - LA
  • 2
Zimmer0
Im currently piecing together my setup to put into my '13 ford f150 supercrew.
Looking to run a component set in the front doors (havent decided on rear components or just coax) and i already have a pair of sundown E8's in a ported enclosure on the way. Amps are still in the works but looking for 5-700w rms for the woofers and 75-100w to the front components. Suggestions needed. Budget friendly please.
My biggest concern is the install. My previous installer has since gone out of business so i'm on the look out for a quality installation.
Hoping members in the louisiana area, lafayette specifically, can point me in the right direction or maybe even install my system.
Any help is appreciated
Would like to keep the remaining components under $600 if possible (components, 2 amps). Will also be running everything thru the stock HU via PAC for the time being.
The previous owner of the E8's ran them off a alpine Mrp500 so may go back to that as they are rather budget friendly. Components, was looking at Hertz, sundown, focal. Not sure on these as i have only ran a free set of polk db series comps in my previous vehicle.
Lafayette, Louisiana. Bout 50mi west of baton rouge.
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
You got plenty of space 30"h x 40.5"w x 65"d even triple baffled, double walled with bracing. What vehicle is this going in may I ask?
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
760
288
Zimmer0
Zimmer0
Lafayette, LA
Zimmer0
saints747
    May 7, 2024
saints747
    May 7, 2024
