jeffgre_6163
Moderators
If this is in the wrong forum please advise and I will move
I recently upgraded the system in my 2020 Mitsubishi dual cab ute.
While it is a HUGE improvement over stock there are a few issues with fading and balance, 2 and four channel switching
Before I take it back to the installer I would like to know where the issues are so I can maybe help get it sorted fast rather than have them try and work it out while I wait for a couple of hours
To cut the installer some slack, I was running late when I picked it up, pushed them to finish the install and left without a full system test.
Advice and where to look would be appreciated
Car:
2020 Mitsubishi Triton duel cab ute
System:
Head unit: Stock 2019/20 Mitsubishi 7.5 touch screen head unit with Carplay etc
Amp: Pioneer CM-D8704 2-3-4 Channel 1200w
Front speakers: Focal Access 165AS components with separate cross overs
Rear: Kicker CSC65 Co-ax
Sub: Kicker hideaway 150s 11HS8
Sound deadening through out doors, floor and roof to come.
Problems:
When set to 2 channel
When set to 4 channel:
Sub woofer works well at either 2 of 4 channel setting
Yes, I am taking it back to the installer but if I can help with a solution it will speed up the fix.
Cheers
Car:
System:
Problems:
- When fading to front rear stays working with no effect to overall fad
- When fading to rear, both front and rear fade out completely
- I have been running it with full fade to the front
- When fade centred it plays all speakers but stereo separation disappears
- [I assume this is because the speaker hook up has set the front right and rear left and the front left and rear right as pairs so cancelled out the audible stereo separation]
- When balanced to right, rear speakers fade to nothing
- When balanced to left, front speakers fade to nothing
- When fade to front, Plays front left and rear right with good stereo separation diagonally across the car
- When fade to rear, Plays front right and rear left with good stereo separation diagonally across the car
Cheers
