NEW Set Up W7 on Turtleback ???
  • 3
can the Turtleback handle the subs????
Although the W7s are very efficient, giving it half of it's rated power will not make them shine. The 500m will feed it roughly 375w RMS @ 3ohms, so that is half of it's rated power. I found that old school 1000-1500 watts RMS @ 2ohms amps, work great with a single 12W7. Now, if they are 10W7s, those 500m will work fine.
I definitely understand. I was thinking the same but I know the old school Punch have “extended” power. Im running 4 W712s so I need to figure out what amps I need because I know one wouldn’t be sufficient for 4 subs at that capacity.
I’m currently running a W7 12 Anniversary Edition on Fosgate 1000.5. I just came into 3 more W7s and 2 Punch 500m (Turtleback) … can the Turtleback handle the subs????
So you have 4 identical W7s? DO you have sufficient airspace for them?
Honestly I think you'd do better trying to flog those old school RF amps to a collector and buying something modern to run your W7s with a bit closer to the 1000W a pop they want and you'll probably want some electrical upgrades along the way either.
Is that the 25 to life RF amp you have? How do you like it?
6
155
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
8
653
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
745
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
Oldvsnew843
CarAudio.com Newbie
Oldvsnew843
South Carolina
hispls
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
