New Setup- Crescendo, Alpine
2 Alpine SWR-12d4Crescendo BC2000D
(Wired at one ohm)
Custom Sealed Box
because ported box won't fit in my trunl (is250)
Please let me know if you have any suggestions
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Plug it in?
(Wired at one ohm)
Custom Sealed Box
I have a suggestion. Run one sub, so that you can run a ported box. Take the $ you were going to spend on 2 subs and buy one sub that is better then them both or at least equal to them. So when you have it in a ported box, you should get the bass you are looking for. Just my opinion.
He never mentioned what bass he wanted. 2 sealed are pretty much the same output as 1 ported, sealed might even be louder unless he tunes the ported box more spl oriented. He already has the equipment might as well seal it.
What music do you listen to? What was ur friend thinking tuning wise?
Stock hu and stock speakers. going sealed because ported wont fit. box will be custom fit. i havent bought the items yet. I will pull the trigger soon, thanks for the feedback
Ohhhhhhh, how much room do you have to work with in those things Ive never seen their trunks. Fit a 15 ported?
I thought you already had everything.
1) you are going to need good electrical if you plan on running that 'endo on 1 ohm. Do your big three and get yourself a nice 2nd battery for the trunk.
2) If you haven't bought the subs, don't. Get a couple of d4/d1 tens or a single d2 15 that can handle the wattage you're going to be putting to it with that amp. That way you will have room for a ported enclosure. Putting all of that power to a sealed setup would be a waste.
1) you are going to need good electrical if you plan on running that 'endo on 1 ohm. Do your big three and get yourself a nice 2nd battery for the trunk. 2) If you haven't bought the subs, don't. Get a couple of d4/d1 tens or a single d2 15 that can handle the wattage you're going to be putting to it with that amp. That way you will have room for a ported enclosure. Putting all of that power to a sealed setup would be a waste.
True story....
Same thing I was saying, but apparently people need more then one person to say everything. I would do a single 12 ported though, but thats because I don't care for how low 15's drop. But gl w/ your build.
I think he would do a 15 because it would be louder, not because it drops lower?
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
581
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
985
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
902
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
bentley12
bentley12
NY
bentley12
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
