New setup idea
You could go with a sams duracell, diehard platinum (sears), duralast platinum (autozone), or something similar as a nice underhood agm batt. If you feel like spending a lot of coin then you could just get with xs.
one of the things about my car is the battery is in the back so running 0 to the amps is too easy.
not sure if anyone else mentioned this, but along with running 1/0 wire to the amp, you should run 0/1 from your batt to your fuse box and alternator
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
725
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
998
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
DeanG
DeanG
Boca Raton,FL
blakgtp
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
