New Sony Headunit + AMP?
  • 2
Atreyix
Hello all,
I have a Saturn LS2, It Has 6 1/2's in the front doors, and 5 1/4's in the rear doors. The speakers were blown when i bought the car so I put in some Pioneer speakers, 6 1/2's (LINK IS HERE) which can be pushed too 40 RMS, and 5 1/4's which can be pushed to 35 RMS(LINK IS HERE). I also put in a Kenwood KDC-255U Head unit in, Which pushes 22 RMS each channel. (LINK IS HERE)
Now my question, If I put in (THIS) Sony head unit, which has a built in AMP of 40 RMS. Would I see a difference? Is 22 vs 40 RMS a pretty big difference or a smaller difference?
You don't have 22 now. It's closer to 12. Every time you double power on paper it's a 3db gain. 3db is the point anyone can tell there is a increase in output. So you could gain 6db. That's a good bit. But you are better of getting a real amp.
721
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
931
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
Atreyix
Atreyix
Wisconsin
LosIsATool
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
