New speakers + amp for Lexus SC300 - need input!!
  • 4
dgreen2321
24
Michigan
Soon I'll be ordering these speakers and amp from onlinecarstereo.com.
Infinity 60.7cs Component Speakers for the front (going to buy mounting bracket because the front slots are only for 4")
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15366
Infinity Kappa 42.9i for the rear deck
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19638
Alpine MRP-F450 4 Channel Amp
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16956
Let me know what you think and give me your input!
This section of the forum is for build logs, as in.. updates and pictures of builds that are already underway or completed.
x2 and that equipment *****...//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
551
It also lowers the amps efficiency and raises the current draw.
5
688
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
897
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
Tons of options in that budget, including the cost of installation,
10
dgreen2321
dgreen2321
Michigan
Echo42987
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
