New sub or port current one?
Lovebass805
I have a mtx terminator I want it to be louder. Amp is generic boss amp rated at 1600 watts and I know it’s nowhere near that I read it’s actually rated at like 275 watts or something but for now it suites my needs
If I buy a ported box would it be louder and sound good or not because the drivers are not tuned made for a ported box?
Or can you recommend a wired dual 12” ported box sub combo that will blow my current sub out of the water with a width no greater than 36”
I know my current subs aren’t the greatest. I just want more bass.
I have a avalanche 18” sealed sub that I love but won’t fit in my car.
I don’t want to break the bank either 400 is limit but 200-300 is more what I’d like to spend on a new sub,no preference in brand
What I like about my current setup is it’s cheap and durable but I want it louder and with no distortion going louder
Thank you.
Sell the amp and the mtx subs and have a new box built for the avalanche and get a real amp for it. Sealed should not be a problem to build for the 18 and fit in a trunk.
I'd literally just sell everything and start all over once you have a healthy budget of 300ish. That boss doesnt make a watt past 160 bridged. Definitely a core issue that needs to be solved along with the box.
Sell all cheap, except the 18" sub...and use that $$ to start all over. Boss amps are complete garbage. Wish people would quit buying them....they do because they're cheap.
yep get rid of it get a jbl 500 for like $99 it would kill your current amp even a pioneer 3003 on that amp ported will amaze u compared to what u are used to..
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
129
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
283
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
462
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
573
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
902
Lovebass805
Lovebass805
Los Angeles
BOOMINGRANDPA
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
