Newbie amp help- thinking of getting RF P400-4 amp
  • 1
dalegtr
OK, I'm a newbie and I'm sure not on the level of many of the folks here but I have a couple basic questions.
On a tight budget so I made do with an
Alpine CDE 102 head unit (18 watts)
Infinity Kappa 692.9i 6x9 speakers in back (110 watts)
Infinity Reference 6022si 6-1/2" speakers in the door (50 watts)
Both pairs of Infinities are technically 2 ohm but with the speaker wire function as 4 ohm speakers.
I knew I'd eventually want to upgrade to an external amp and originally thought of the Alpine KTP 445 (45 watts). I'm now looking at a Rockford Fosgate P400-4 (50 watts but they often are actually higher in actuality).
My questions:
1) If the amp rates at 75 watts or so (or more?), will this harm the 50 watt Infinities? I don't play my music TOO loudly and only for around 1 hour at a time on commutes.
The 6022si's were the cheapest 6.5" speakers I could afford that would handle 50 watts. I wanted something that could handle 100 watts like the back speakers but could not afford this. Should I match these eventually? Will the RF P400-4 make good use of the 110 watt 6x9's?
2) What is the best way to add a subwoofer setup later on? The RF P400-4 can run in 2 or 4 channels. The Alpine only has 2 sets of preamp outputs in back. Should I keep all 4 speakers and use the P400-4 to power them, then rig another amp for a sub? I imagine Y-adapters would make this possible?
Thanks for any advice!
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
822
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
11
Wow. That's a nice truck. Where I live there are few cars and trucks that use only one amplifier to power the speakers. So already noticeable...
6
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
9
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
dalegtr
dalegtr
Chicago
dalegtr
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
