Newbie needshelp
  • 4
turbokat1320
Can i power 6 speaker with a 4 channel helix dsp amp have 2 blam tweeters 2 blam 3” mids in stock tweetter location and 2 8” blams in door in my 2017 Chevy Colorado extra cab looking for sound quality for now ! Also will be adding 2 Jo 10w3-3-2 subs in ported box as soon as I can afford an amp??
Probably no good way to run all of those speakers from less than 6 channels. You can get 3 way passive crossovers for pretty cheap on Amazon, go that way and strap that amp to run 2 channel.
You'll need a passive crossover. I'd probably cross the mid somewhere between 3-700hz on the low end. I don't which tweeter you have, but usually 2x the tweeter's FS is a good crossover point.
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
824
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
I'm in Detroit too. Came for boat audio but that area is rather lacking on here.
turbokat1320
turbokat1320
prescott az
Silicon oxide
    May 18, 2024
    May 18, 2024
