NIB Skar IVX12D2v2
  • 2
AnthonyO
Budget Banger Connoisseur
Brand New in Box Skar IVX12D2v2 looking to trade for (What do you got?) other car audio. Will consider 1/0 gauge accessories, components, etc.
Specifications
Skar Audio IVX-12v2 D2 - 12" Component Car Subwoofer
Dual 2 Ohm Voice Coil Configuration
Peak Power : 800 Watts
RMS Power : 400 Watts
Competition Grade Pressed Paper Cone
Rubber Surround
Advanced Air Flow Cooling System
2" High Temperature Copper Voice Coil
Frequency Response : 35 - 600 Hz
Sensitivity : 89.5 dB
Fs : 38.0 Hz
Re : 4.1 Ohms
Qms : 2.97
Qes : 0.47
Qts : 0.41
Nref : .56 %
Cms : 0.13 mm/N
Bl : 16.5 n/a
Vas : 47.7 L
Mms : 133 gr
Sd : 510 cm^2
Xmax : 11 mm
Enclosure Specifications
Sealed Volume : 1.50 ft^3
Ported Volume : 1.75 ft^3
Port Area : 23 sq.in.
Port Length : 19"
Tuning Frequency : 38 Hz
Mounting Depth : 5.9"
Cut-Out Diameter : 11.2"
Magnet Diameter : 6.3"
Subwoofer Displacement : 0.12 ft^3
Enclosure specifications do not include subwoofer, bracing, and port displacement
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
563
945
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
AnthonyO
AnthonyO
Minot, North Dakota, United States
AnthonyO
