NIB Skar IVX12D2v2
  • 2
AnthonyO
Budget Banger Connoisseur
Brand New in Box Skar IVX12D2v2 looking to trade for (What do you got?) other car audio. Will consider 1/0 gauge accessories, components, etc.
Specifications
Skar Audio IVX-12v2 D2 - 12" Component Car Subwoofer
Dual 2 Ohm Voice Coil Configuration
Peak Power : 800 Watts
RMS Power : 400 Watts
Competition Grade Pressed Paper Cone
Rubber Surround
Advanced Air Flow Cooling System
2" High Temperature Copper Voice Coil
Frequency Response : 35 - 600 Hz
Sensitivity : 89.5 dB
Fs : 38.0 Hz
Re : 4.1 Ohms
Qms : 2.97
Qes : 0.47
Qts : 0.41
Nref : .56 %
Cms : 0.13 mm/N
Bl : 16.5 n/a
Vas : 47.7 L
Mms : 133 gr
Sd : 510 cm^2
Xmax : 11 mm
Enclosure Specifications
Sealed Volume : 1.50 ft^3
Ported Volume : 1.75 ft^3
Port Area : 23 sq.in.
Port Length : 19"
Tuning Frequency : 38 Hz
Mounting Depth : 5.9"
Cut-Out Diameter : 11.2"
Magnet Diameter : 6.3"
Subwoofer Displacement : 0.12 ft^3
Enclosure specifications do not include subwoofer, bracing, and port displacement
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
11
648
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
940
AnthonyO
AnthonyO
Minot, North Dakota, United States
AnthonyO
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
