no more lowes? :(
907tacokid
alright so i had this problem with my left sub a few months ago but i tried to do the same thing and it wouldnt work.
i have two sonic soundlab transonic 10 inch subs. 700-900rms each, was running them at around 1000rms each at 1ohm. but got rid of that amp (stupid of me) and replaced it with a ssl 5000d amp. amp is pile of ****, isnt stable at 1ohm so got it at 4ohms.
the right sub playes pull power. great sound level and sound quality. but the left sub dosent play lowes. has just as good of sound above like 60hz (totaly guessing about that number)
but as soon as it gets lower it dosent play as much. seems like it stayes at lower volume. like sub sonic was on or something but its only affecting one sub.
dont know what the problem could be. any help would be greatly apreciated. if you need more info just let me know.
the old problem was the negative lead on the sub where it turnes into spider leades was only held on by like 3 or 4 strands of copper. but i changed all the terminals with high dollar rings and tightened them properly. check them when this started happening and they all still look good.
thanks for any help in advanced.
Check and make sure your wiring configuration is correct for the subwoofers @ 4ohms.I bet if you just hook one up it will hit harder than both together??Meaning if so, you ohms load isnt correct with your sub wiring configuration??Check that out,alot of people think that you just keep the wiring the same on the subs, and just change the wiring on the amp.Check your wiring.Agood solid 400watts should still bang the crap out of any vehicle @4ohms.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
558
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
725
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
877
907tacokid
907tacokid
chugiak alaska
hispls
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
