No resistance from Hertz Sub in custom enclosure
  • 2
So I've been having some issues with my audio system in my car. I have the following equipment:
-Pioneer DEH-80PRS
-Kicker KX650.4
-CDT ES62i Speakers
-Hertz ES250 Subwoofer
The issue i want to fix, is that my subwoofer which is in it's custom enclosure is not working. I've tested the sub wire's continuity (which is brand new & was passed about 3 years ago). I've made sure to test the subwoofer in different channels on the amp & no sound at all. My speakers work in any of the channels but no sound for the sub.
I took the sub out of my car tested it according to troubleshooting guides & there is no resistance on the cable end. Anything else I should test? Get the silicone seal off the woofer & test directly at the sub connection itself?
So I've been having some issues with my audio system in my car. I have the following equipment:pioneer DEH-80PRS
-Kicker KX650.4
-CDT ES62i Speakers
Pull the sub. Test the terminals directly. If there is no resistance. It's a direct short and the sub is dead.
Sent from my XT1710-02 using Tapatalk
Ok I'll take the sub out & test the terminals directly.
Any reason why it would die suddenly?
Can this sub be repaired?
If the sub is damaged, I'll get an estimate to repair but could you guys recommend a replacement subs around 100-150$? I think the sub needs to be somewhat of a shallow mount.
Here is my sub & enclosure.
https://www.scienceofspeed.com/index.php/nsx/ipp/stereo-system-accessories/scienceofspeed-subwoofer-enclosure-for-nsx.html
http://www.hertzaudiovideo.com/car-audio-subwoofers-energy-es250_5/
Here's my AMP's specs. I'm curious, if I'm using 2 out of 4 channels for CDT speakers how much power have they been receiving? Now for my sub. When I use the last 2 channels & bridge them together. How much power has my sub been receiving?
RMS Power in Watts, All Channels Driven
@ 14.4V,
4Ω Stereo,
@ 2Ω Stereo,
@ 4Ω Mono,
@ 12.5V,
4Ω Stereo, 0.085% THD+N 4 x 35 4 x 70 4 x 90
@ 2Ω Stereo, 0.5% THD+N 4 x 70 4 x 135 4 x 180
@ 4Ω Mono, 0.5% THD+N 2 x 130 2 x 250 2 x 325
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
7
What brands are offered in your location? Ive heard that Ground Zero and Stetsom are a great option and even Taramps
that will be $40 my btc wallet is 5748384758585854445... jk! :ROFLMAO:
8
s2g-unit
s2g-unit
NY, Redding, CT & Montreal
s2g-unit
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
