No sound from rear speakers, HELP!
  • 3
at_viper
WI
I just got done wiring in 4 new speakers and a deck into my 03 Vue (w/advanced audio system) I went to test my speakers (each one by using the fade and balance feature) and everything worked. (they all worked great) before i reassembled the door I tested again the speakers i was currently working on (right rear) the connection came undone. The wire had come out of the crimp connector. I was then pulling to get the crimp connector off and finally it came off. I hooked it back up and now i have NO SOUND in the rear. Neither the left rear or right rear speakers work!!!!!! Both front speakers and the sub work great. Is there a fuse for the rear speakers anywhere or what else could this be? NEED HELP ASAP!
THANK YOU!
are you sure you fixed that correctly? This is where your problem started and this is where your problem is redo these wires or get the crimping tool
I never had an issue with the left rear, the right rear is the connection issue. I recrimped with a tool the right rear connection turned the car on and neither the left or right rear speakers worked.
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
5
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
at_viper
at_viper
WI
keep_hope_alive
Decebal
    Jun 10, 2024
