No Voltage in Remote wire and no Sound on Front Rear Right Channel RCA
  • 3
hassane3469
CarAudio.com Newbie
Hello
I have Installed Pioneer ZF-9350 BT
With 3 Amps Separate for Front Rear and Sub
I checked with volt meter their is NO Voltage coming from Remote Wire
Also RCA have alot of Noise as well Right channel RCA Front and Rear both have no Sound.
What should i do?
Is there any fuse in Remote wire?
Before remote wire was perfectly working. But i think RCA touched the Ground and after that this happened. No power in remote wire and Became noisy and righ front and rear no Sound
Remote turn on. Going to check it later this week. Almost 100% certain it's something with the amp. I am assuming that a resistor inside went bad...
9
Hello I have Installed Pioneer ZF-9350 BT With 3 Amps Separate for Front Rear and Sub I checked with volt meter their is NO Voltage coming...
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
325
hassane3469
CarAudio.com Newbie
hassane3469
South Korea
hassane3469
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
