System Hiss - even @ min volume
  • 4
Vansounds
CarAudio.com Newbie
UK
Hi All- first time post, would be great to get some help if possible.
System, i-phone/tidal-->bluetooth receiver-->RCA to Bit one virtuoso-->Hertz ML amps-->Hertz ML front end.
When powering on I get a significant hissing which doesn't go away. With some volume the music means it can't be heard, but something is definitely wrong here. It's definitely a hiss and not a grounding issue, it's high frequency and consistent. It doesn't get louder when I increase the volume either - so it's something in the system causing this.
Any ideas?
Gains too high?
Maybe try powering it up without the bluetooth receiver and phone and see if it is still present.
Have you tried any trouble shooting as of yet? that way were not telling you to try stuff you already did.
Gains too high?
Thanks for the reply mate....exactly as you suggested. And basic - yes, the gains were too high! This is my first install - still working things out!!
Any ideas?
Can you running optical into that Bit processor?
Your main input for noise is going to be between the Bluetooth and the processor. If you have the option, I highly recommend switching from RCA to optical.
I'm glad you got it sorted, I would suggest running your amp gains as low as possible with that virtuoso. I believe it can put out 8v, so you can run the amp gains really low and have a very low noise floor for your stage.
Matt
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
518
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
Vansounds
CarAudio.com Newbie
Vansounds
UK
mat3833
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
