Noise or distortion
  • 2
What’s completing the circuit on the speaker wires? If there’s no speakers, then what’s completing the circuit?
When setting my gains I disconnect the subs. When I’m done the amp is connected to 2 12” EVLs at 1 ohm final load.
I just noticed your location on your signature says Sarasota FL, I am in Port St Lucie FL. I am due east of you lol.
PM me if you want. My box builder and his shop isn’t too far from me either.
So, to follow up, I got everything working properly again. If you refer to the photos I sent of the amp internals, you can see there is that white...
14
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
Taxed1
Taxed1
Florida, USA
Buck
    May 31, 2024
    May 24, 2024
