Noob here, need help.
  • 3
jdubin94
30
Miami
Hi guys, as the title suggests, I'm new to this forum and I'm very new to car audio. My tweeters went not too long ago. i bought a pair of cheap ones ($10) off Amazon that had good reviews. I tried installing them by directly splicing the four wires together, at first without any cross over, and then with a capacitor inline with the wires. Both times, the tweeters produced a considerable hiss that wasn't bearable. At first I thought it was because I didn't install a proper crossover like everywhere I read suggested. After talking to an audio installation place, i'm guessing it's simply because the tweeters were $10. Thoughts? I think I need to get more expensive ones. I also decided that I want to upgrade my components too. The place said I wouldn't be able to find a good pair of tweeters for less than $100 and a pair of components for less than $200. I don't think that's true.. And on top of that, they'd charge me an arm and a leg to install them.
So, with that being said, what do you guys think I should be able to find a good pair of tweeters and components for? I am not an audiophile. I would just like a noticeable upgrade, from my old, stock Bose system in my G35. I feel like I could find solid tweeters for $50 and components for $100.
Also, when looking for tweeters and components, that I may install myself, would it make my life a lot easier finding quality ones that come together as a package, with a crossover?
Diamond makes pretty good stuff, can't agrue with Nuckin on that. I've ran them several times and liked them a lot. Hertz makes good stuff, but honestly being that you're just entering into this world even a set of Kenwood components would probably rock your world. Many choices to choose from. Good luck.
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
5
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
3K
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
8
The link is from JL audio. It’s a how to set amp levels. The process of setting levels is the same for whatever amp.
5
jdubin94
jdubin94
Miami
UsAmpsFreak
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
