Noob question incoming.
  • 5
KMS
SoCal
I have a hatchback, box is sub up port back and was wondering if it's better to have my box closest to the seats, or box against the back of the hatch? //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Without doing all the math, which costs the same as just designing the exact enclosure to yield your desired results....you should just move it back and forth in small increments to determine which position does the most of what you like.
Yep, just move it around until you find what works best for you. There is no math equation that will determine this, because what sounds best to you is subjective. You may enjoy a flatter response, or you might prefer a response that has an exaggerated low end.
I seen you on TV the other day on a rerun of a show..I'm sure you know which //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
5
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
3K
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
8
KMS
KMS
SoCal
pro-rabbit
