Noob question
  • 1
BigSachsy1
CarAudio.com Recruit
So I have a 4 channel Dual xpr-84d running my front tweets and rear coaxials. I didnt have the RCAs I needed for my front mids (not long enough) so the installer hooked up my rear coaxials and front tweets until the RCAs were installed. So now, I installed them, and I dont know which wires to cut. The front left door speaker wire is the same color as the tweeter wire. The speakers are 2 8ohm skar fsx 6.5s and 2 4 ohm massive audio ct 2 tweeters. Seems like it should be a simple fix but for some reason I cant figure it out. If anyone could point me in the right direction it would be awesome.
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
5
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
3K
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
8
BigSachsy1
BigSachsy1
Centennial, CO
BigSachsy1
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
