OEM interface
  • 3
MBlood66
I'm redoing the audio in my '07 Mazda3 Hatch and I'm not sure what interface I should get for it. I want aftermarket sound without replacing the factory unit because it just looks so **** good. I was looking at the MTX Re-q5, but I'm worried about alternator hum because the outputs are less than 4 volts. Also, I'm not looking to spend over $120. This system is going to be all JL if that means anything.
Thank you!
Never looked into one so I just read up on it. It seems legit, not exactly sure if it will actually make things sound better but it should make aftermarket installation easier.
---------- Post added at 02:58 PM ---------- Previous post was at 02:58 PM ----------
By the way the voltage on those outputs are just fine
The situation has changed. My friend has both the MTX Re-q5 and an AudioControl LC8i and wants to give me one while he gets the other. What are the pros and cons of each? Which one will sound cleaner with better sound quality when tuned?
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
657
Here is a great little item that will do the bull work of what you want to do. The nice thing is that it doesn’t require a separate remote turn...
4
Since you plan on keeping the factory head unit, You need to first verify what ohm rating your factory speakers and head unit are. Some are 4...
MBlood66
MBlood66
West Deptford
fasfocus00
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
