Ohm to watt ratio
  • 2
Originally posted by jrmax:How much amp do you run to a sub at 2 ohm half of max of what? Do you run different watts per ohms?
Not sure I understand the question but ohm has more to do with wiring. Your amp has to be rated to accept the ohm you are shotting for and your sub has to be wired right to attain that ohm as well.
You shouldn't be running different watts to subs wired to one amp, if you are there is something wrong unless the amp is designed to give different amounts of power (some multi channel amps are able to be bridged to a sub and still have 4 channels for the mids and highs)
It also lowers the amps efficiency and raises the current draw.
688
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
490
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
jrmax
jrmax
oklahoma
LegendZ28
