ohms
  • 2
slick rick- if you have the 8ohm subs call
the subs sub#1 and sub#2 take the positive and
minus of sub #1 and wire it to the positive and
minus of sub#2 both subs are now in a 4ohm load
now take the positive and negative of your
bridge amp and wire it to sub#1 positive and minus
only. if you are planning to buy 4ohm subs
make sure your amp is stable into 2ohm bridge/mono. because
wiring both 4ohm subs in parallel (meaning
plus to plus and minus to minus will present a
2ohm load two your amp) so make sure your amp is
stable into a 2ohm bridge/mono load
will bridging the amp make it n e better considering the bridged powr is the same as the channeled power, id like 2 just take out the old pioneers and pop in the new kicker comps 10's, i hae circuit city install my amp and subs, so i figure i can just put in the new subs myself.
slick rick--what kind of amp do you have.
and what is the power rating at 4ohm bridge/mono
some better built amps will double there stereo channel
power into a bridge load. ( for example)
precision power pcx 2200
200x2 into 4ohm stereo
400x2 into 2ohms stereo
800x1 into 4ohm bridge/mono
did you also buy a sub box with speakers from circuit city
(meaning factory made) example mtx, jlaudio,etc
you might void the warranty if you remove the subs
from the box. check with circuit city first.//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
its ok. i have an mtx thunder 102
heres the stats:
rms- 25x2 @ 4 ohms
50x2@ 2 ohms
100 watts bridged@4 ohms
dynamic power(peak)-
65x2@ 4 ohms
125x2@ 2 ohms
250 watts brdiged @ 4 ohms
i really dont feel like bridging it, but if it will make it sound better, than i will. i wana put in 2 kicker comp 10's, and i hope the amp is good enough. and do they make non free-air models, cuz all i seem 2 find is free air models. the vox i have and subs r not from circuity city, i just had em installed there. n e advice is welcome.
Yeah, if you haven't bought em yet, then get a matching third sub. I would wire them to 1.3ohm, unless for some reason, you have some really...
6
Follow the wiring diagram for the final 1 ohm load for the 6.5s and the 1k amplifier...
Thank you for all your help and I'll let you know how it all turns out. I'm putting it n a kia optima. I hope that it sounds as good as i think it...
10
slick rick
OG
slick rick
Violates Miranda
slick rick
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
