what kind of amp should i use
  • 2
if you got the 4ohm vc you should go with an amp with at least 400 watts rms at 4ohm or get an am that is 1ohm stable then get an amp that pushes 400 rms at 1ohm. if you got the 8ohm get an amp that pushes 400 rms at 2ohms. the mtx Thunder4244 4-Channel Amplifier would be good for either it will push 400rms at 4ohms bridged and 400 at 2ohms. hope this helps
I can relate to your problem because I just purchased 2 12'' MTX 4000s and wondered how much they can pound. I noticed that they have quite a bit of excursion, and handle even the lowest notes. I strapped them in a sealed dual carpeted wedge box and hooked them up to a 450x2 amp and put them in my trunk firing into the seat so the wedge was 1'' parallel to the back of the seat. I'll tell you straight up, they ****ing POUND. They weighed in at an incredible 158 dB! But it all depends on where they are going, but that is was I would recommend.
The amp was a kicker 2-channel 900 watt bass amp, but jensens and kenwoods can throw em' down too.
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
11
6
117
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
297
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
305
jcchase_17
jcchase_17
kennesaw ga
forum_punk
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
