Okay, new to the biz, a few questions....
  • 2
rand
Okay, I have just got two pioneer 12" subs, wired in the box, and a 150W Punch amp for christmas. Today I bought the wires, fosgates, and need to still buy a good cd stereo. What would be a good buy? I am looking for something not too much more than 100 bucks...also, what is the difference between having one or two preouts? Does it make a difference? Should I get another amp to help power my subs? If so, should i also get a power cap so the juice from my battery wont be totally consumed by my stereo? Any help is better than the little knowledge I already have...thanks...
Okay a deck close to $100 bucks. That's gonna be a tough one. Check out ebay maybe.
There are a couple of reasons for more than one set of preamp outputs on a headunit. Ease of adding additional amps for mids and highs. If using both sets usually you will have the ability to use the fader on the head unit. Some decks have a third set for a sub output. Does it make a difference ? If you want to upgrade later yes. If you only plan on using one amp no. I doubt you will need another amp for your subs. I seriously doubt you will need a cap. A cap doesn't act like a battery. A cap will only offer very,very short bursts of power. About the only thing a cap will help you with is to keep your lights from dimming. I don't think you will have dimming problems.
No problem. If you need anymore help let me know
Most people run bigger wire than they need. It won’t hurt anything and is actually recommended here. Those reducers work great but I’d recommend...
694
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
8
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
7
I found this, can it be done with snapon modis ultra scanner which i have...
11
rand
rand
Houston
ramos
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
