Opinions and decisions
  • 3
amedeuce
:crap:
1,825
CA
I'm not new to car audio by any means but have been out of the game for a little bit and currently building a partially budget conscience system in a new vehicle. I have some equipment from a previous install in my old f-150.
Vehicle 2014 toyota tacoma double cab
Keeping stock navi screen h/u
No rear fill
Subs to be installed 2 10" Memphis Shallow mounts SC10S4 - I've owned these for a while
Sub amplifier Kicker zx1000.1 - birthed at 1122 - Also have had for a while
Recently purchased Mids amp - Alpine PDX-F4 birthed at 118x4@4ohm or 200x2@4ohm bridged
Contemplating the following purchases
TacoTunes Recurve (EZQ) - $300'ish
ID CSX64 components - $300'ish
I guess my main questions here are if I should I attempt to run these Mids active with the recurve EQ? OR use the passive xovers and bridge the amp for more power?
Should i consider other options as far as Mids? Any ideas or opinions?
I won't have any tweaking capability from the head unit to play around with setting on the active setup and would have to rely on the recurve for all that.
Thanks for your help and opinions
Well maybe I'll just have to upgrade the stock screen to an aftermarket head unit screen. Who's making good ones these days? Alpine? Kenwood? Other?
I was just thinking pioneer. Have always used alpine single din h/u's. Pioneer might be the way to go for double din screen. Thanks
No rear fill
Analog processors like that taco tunes and the audiocontrol lci7 are dinosaurs of the past. Get a digital signal processor (can find a used rockford 3sixty.3 for around 300 or use a soundstream harmony for 200 on ebay. The amount of tuning you get with a modern day DSP is way beyond anything those old fossils can dream of. You can certainly keep the stock head unit and proceed with everything else minus the tacotunes.
There goes the budget. I ordered everything. ID CSX64, Pioneer AVH-4100NEX, Wire kit, RCA's, sound deadener, misc cables/adaptors for steering wheel controls... Not exactly the route I was initially going but I think this will be much much better.
Giving subs more power really wakes them up. The MRP-500 is pretty low power. You would really notice more authority in your bass.
8
820
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
JL RD1500.1 does rated power @1 or 2 ohms, Does 1800 to 1900 watts in tests I've seen.. Designed buy a guy who designed old school PPI and Xtant...
13
amedeuce
:crap:
amedeuce
CA
amedeuce
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
