nate1017
Okay so I'm pretty sure this is a part of my problem may not be all though. Got everything installed yesterday by the guy who built my box and I later noticed that the ground wire from amp isn't exactly ideal. Nothing grinded down to bare metal on a pretty heavily painted area, it is bolted down,but I'm likely to move that on one of these days it isn't storming or 100 degrees(could be a while). Regardless I'm slightly concerned because my amp runs hot after a trip to town and back(like 20 min drive), subs also get a little warm and I am seeing voltage drops from 14 down to 11.6 at the lowest voltage is from my stock HU. Would a faulty ground cause these problems. Don't have a Big 3 done yet but that is in the near future here and I know that will help voltage issue some. I have a stock 130a alt,with a duralast 650 cca under the hood and 0 ga power/ground wires. If I left out anything you may need to know just ask also amp is a SAE 1200D any help is appreciated guys thank you
