orion 275r or 2250 "THE BEAST"
cagodinez
I need some help please, I don't wich one of these amps to go with, what would be better for my setup? I'm trying to puch as much power as I can to my cmpx2 15"sub dual 4ohm voice coils. Any info greatly appreciated.
ORION HCCA 275R ORION HCCA 2250 "THE BEAST"
2 X 75 @ 4 OHMS 2 X 250 @ 4 OHMS
2 X 150 @ 2 OHMS 2 X 500 @ 2 OHMS
2 X 300 @ 1 OHM 1 X 1000 @ 1 OHM
2 X 600 @ 1/2 OHM
1 X 300 @ 4 OHMS BRIDGE
1 X 600 @ 2 OHMS BRIDGE
1 X 1200 @ 1 OHM BRIDGE
If you are running a single sub with dual 4 ohm coils the XTR-2250 is the obvious choice. If you were running two of them were you could get down to 1 ohm the 275R would be the better choice.
The 2250 is not meant to run below a 4 ohm bridged load, FWIW. I know that people have claimed to run them at just about every conceivable load out there but most of these people making these claims have proven time and again that they don't have a clue.
Without pushing the limits of amp stability, the 275r is rated to do more power at a load that you can wire that amp to. 600@2ohm vs. 500@8ohms.
KILROY, is that 600x2@2ohm or 600x1@2ohm? How would I wire the amp and sub to achieve this? Would it have to be bridged mono? Thankyou for the information.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
cagodinez
cagodinez
Riverside, CA
AudioAnonymous
Decebal
    Jun 10, 2024
