orion HCCA250
  • 4
1 have a gen 1 that you can fry eggs on when bridged low.
revrider is the expert, but I think gen 2 and 3 are good, gen 1 is ok.
example of a v1 from roe
v2 or v3
You also need a bridging module for the G1 amps whereas the later generations come with a mono switch that inverts one of channels for you.
ETA:
Stereo Stats
50 per channel @ 4 ohms
100 per channel @ 2 ohms
200 per channel @ 1 ohm
400 per channel @ 1/2 ohm
Mono stats:
200 @ 4 ohms
400 @ 2 ohms
800 @ 1 ohm
Real life stats - I measured output on a HCCA 250 G4 @ 100 watts RMS per channel on a 4 ohm load just prior to clipping with a 50 Hz test tone. The HCCA 225 G5 that I have did 73 watts per channel @ 4 under the same conditions.
The only downside is these amps are HUGE footprint, current hungry, Class AB beasts. At lower ohm loads, expect a HCCA 250 to continuously draw close to 80 amps and heat up like you wouldn't believe. On component the HCCAs are great because they have tons more headroom than most 4 ohm amplifiers with the same power rating.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
846
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
94civik
94civik
MN
gunz4me
    May 18, 2024
    May 18, 2024
