Boominburban
yea, I can tune it with 2 4" aero ports, but I can't get the port velocity to an acceptable level ...
actually you can just run a single 6 inch aero with less space. Its just how efficient flared aeros can be, you only need 9-13 square inches of port per cubic feet with flared aeros compared to 12-16 with slot ports and the thickness of the slot ports eat up a lot of airspace too. However its a lot easier to tune and modify with slot ports.so what you saying is with the amount of space i have if i add 4 more inches to depth to the box and run 2 4 inch flared aero ports instead of a vented box i could run 2 10's then ?
i notice the box stands 14" tall and all i have is 10 inches to work with ?actually you can just run a single 6 inch aero
and we don't want that we want as little as possible if not none.right , I tried that too, but the port noise will be high ...
my bad was going off of gotgixer's dimensions in an earlier post.i notice the box stands 14" tall and all i have is 10 inches to work with ?
---------- Post added at 10:14 PM ---------- Previous post was at 10:13 PM ----------
well if you increase the depth to 19, with upfire subs and rear fire port, you can definitely make 2 10s work slotted. Might even sound better that way since i just remembered your car's a hatchback.i was aiming more for sub up port forward instead of sub and port forward. it's the only way i would be able to pull it off since that is what i had to do with the box i built for the sub i have now.
now is this with a slotted or a flared aeroAlright, how about a 31.5 x 19 x 10 box
And with a rear fire port, you shouldn't notice any port noise ...
and that is why i built the box i have now with sub up so the sub would hit off the hatch. question i just went outside and i see i have 38 instead of 35 inches for left to right could i to replace adding depth and just add it to width and still make it fine.well if you increase the depth to 19, with upfire subs and rear fire port, you can definitely make 2 10s work slotted. Might even sound better that way since i just remembered your car's a hatchback.
alright man you take care and thanks for the help man good night.All I know is, I have to get back up for work @ 4:30 am ... I worked 13hrs today and 13 hrs tomorrow ...
---------- Post added at 11:38 PM ---------- Previous post was at 11:37 PM ----------
It is time to check the inside of the eyelids out fella's ....
