Parallel 6th order/RDS 6.5
It doesn’t like to play below 30 HZ. I have a -24 db SSF set at 30 along with a limiter that cuts it back when it senses a clipped signal. Effective bandwidth is from 30-65 HZ. Really solid sounding on music. Where you really have to be careful is around the 60-65 HZ area. The sub is only moving about 3 mm at 60 cycles per second, so it’s easy to burn a coil in that little spot with test tones. You can still hear over excursion in a parallel tune, unlike a series tune, where you might not hear over excursion until it’s already jumped it’s gap and caused damage. I had this thing really stinky this afternoon running test tones at my cabin gain frequency. That’s at about 59 HZ.
30 hz. is great for a 6-½" sub IMO.
What’s your rear port area per cube?
Well, they don't sell the CDTs so there is that... I sold electronics (audio) years ago, in a very hi-end environment. one of the emphasis they...
5
873
If you want to do this I'd suggest you buy one of those PAC or Audiopipe 3 way passive crossovers off Amazon to split the signal between the three...
SlugButter
CarAudio.com VIP
SlugButter
arizona
SlugButter
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
