Partially installed big 3. Is this a problem?
  • 3
I was in the middle of installing the big 3. I got a work call and had to run. The only thing i got done was the power wire from alt to battery, neither ground wire has been installed. I have to work again tomorrow. Will this damage anything for a couple of days until i can finish the install? Should i leave the radio off?
nah you'll be fine. May exp some voltage drop if you do crank it sky high but monitor it anyway even if you don't, just to be sure.
thank you for the quick reply ,I contacted LordofBass and the part is backordered but I'm on a waiting list Cheers:)
The install looks very nice and clean for sure. Thanks for sharing the pics as well as your experiences
Gatorade
Gatorade
Lexington, KY
Boomin_tahoe
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
