Passive x/o
  • 4
The Camry
Hey, I Try.
Thinking about how to run multiple speakers in a boat set up off a 2 channel. Essentially 4 6.5s and 4 tweets.
This would have to be done using passives and some interesting ohm loads. Stereo separation in an open air boat means nothing so a mono signsl would be just fine to all speakers. its late and I dont wanna think atm. How would you do this?
Bridge the amp and run both mid and tweet in parallel pairs of components & then in series between the pairs, gives you a total of 4 ohms in mono. To clarify. If you had a front set & a rear set, you would wire the front together in parallel. Same for the rear, then series the front and rear together.
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
795
Yep. It would be a little over 3 wired in series, but that’s fine.
853
Agreed. I was actually thinking of building a 3-way passive and I compared the cost to a Dayton DSP and it makes no sense to go passive.
10
The Camry
Hey, I Try.
The Camry
Western Oregon
El-Camino
maylar
    Jun 2, 2024
    Jun 1, 2024
