Physical noise from subwoofer cone
  • 2
cool9
France
Just bought Rockwood RFP4410 (10-200 W RMS, 400 W Max, 4 ohm) sub and MTX 4202 (200 W RMS bridged into 4 ohm) and I get physical noise from the sub cone when it moves. Is this a bad subwoofer? I wasn't pushing it hard at all. I had just as much noise from the cone as I had bass so something tells me something's wrong.
Sub is used but in excellent condition, amp is new. Is there a dust cap in the sub cone?
alot of low-end drivers have noisy suspenion.
my audiobahn's make that noise too, but thier is nothing you can do about it.
is it in a sealed box???
No, I just bought it. I just wanted to make sure it worked before I mounted it. Guess I'll have to buy another one.
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
cool9
cool9
France
cool9
maylar
    Jun 2, 2024
    Jun 1, 2024
