Planet Audio P2250D
Spooney
Planet Audio P2250D
Amp is in good physical shape and works flawlessly.It has some light scratching but looks very respectable. I'd give it 7.5-8/10 physically and 10/10 functionally. Amp is rated for 2250 x 1 into 1 ohm,1200 x 1 into 2 ohms, and 650 x 1 into 4 ohms(specs taken from the manual for this amp found on planet audio's website in the support section). For those who don't know this amp uses the same board as the Power Acoustik A3000db so with the right electrical you should see 2K out of this thing. Power Inputs look to be 2 gauge and the speaker outputs look to handle 8 gauge wire. Amp has built in variable lowpass filter, variable subsonic filter,bass boost,phase control, and rca outputs.
200 Shipped in the lower 48 only. Will also listen to trade offers but I prefer to sell outright
Shipping Included in price. I usually ship either USPS,UPS,or Fed Ex. I can ship any one of those at your request but I typically use whichever one helps me get the amp out the fastest.
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
132
Spooney
Spooney
Charlotte,MI,USA
audiobaun
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
