Please 2amps Help!
  • 3
TheDem6n
Please help i have a Jbl Gto 520W (4 ch) and a old american pro 400W (2ch) amps!
How do i go about connecting them both, i was told to get a power cap and run 2 cables of that, or should i just get a distribution block as i heard the caps are a bad idea! P.s. i only have a standard battery would 2amps not put 2 much starin on my electrics?????
do the big 3 upgrade, get a ditro block that has 1 - 4-0 guage input and 2 - 4 gauge outputs.. i personally went with the Phoenix Gold (gold level) TXBBKF2. it cost me almost $30 with s/h, but a very nice distrobution block.. 1 - 1 ga in and 2 - 4 ga outs.. then simply run a 4 ga ground from each amp to the same point on the vehicle..
PS it doesnt come with fuses, so make sure you pick some up..
i have a distributor at work i get them from.. we dont really sell car audio, but i have allot of accessory catalogs with PG wiring and accessories..
Thatnx jasperpso! on a hunt for a new cable no as only hav a 8awg at the moment! had the 2ch lying about for almost a year now since getting a 4ch so thought as it not worth selling myght aswell fit it, 2 is better than 1 anyway!
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
669
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
577
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
TheDem6n
TheDem6n
Cambridge, Uk
TheDem6n
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
