Please help, i have a question
  • 3
jsross
Hello everyone,
To be upfront and honest with everyone i signed up just to get help. I did look through the forum to be sure this was the right place to post this. Hopefully i was correct.
My wife has a 2002 grand am gt with the momsoon sound system. Her monsoon system was locked out so we bought her a new HU. We then found out her stock monsoon speakers were blown.
So we went to walmart and just bought a pait of Sony Xplods. The Monsoon has a dual +/- wires that run into a clip connecting it to the amp. The Xplods do not. So i ran both positive wires to the positive ends and negative to the negative ends, tested it and it put out sound so i put her speakers in like that.
Whenever the Xplods try to put out bass they crackle horribly. The speakers themselves do put out audio. I checked everything on the HU and turned the loudness option off and the equalizer set to vocal etc etc. However her car has no bass at all. As i said, when it tries to hit the speakers crackle.
What is causing this and how can i fix it?
I appreciate any help with this.
Thank you,
Jason
The only way to really handle this problem is to bypass or remove the Monsoon amplifier and wire the speakers directly to the head unit. This would get your Sony speakers to sound better.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
952
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
jsross
jsross
United States
calebkhill
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
