please help me out?
  • 3
hottieb99
Hi
I am new on the forum and I have a couple of questions for school. I am doing a report on the advantages of ported sealed and band pass boxes but I need to know the simple definitions of
what a dbl is
what a subwoofer does and why do we prefer to have them
what is a hertz
what is watts
can someone please help me out? I would greatly appreciate it. I don't want to keep asking my boyfriend for everything, I just don't want to frustrate him
thank you so much
DB = decibels it is the standard means of measuring how loud something is..airplanes..stereos etc.etc
A subwoofer is a speaker (transducer) that plays frequencies lower than most musical instruments or voices can go.. Lower harmonics... If that doesnt help ask the schools music teacher or band instructor..
Hertz = is the measurement of frequencies low numbers like 25 hertz would be played by a subwoofer.. 15000 hertz would in the range of a tweeter.
Watts is a means of measuring electrical power..A library would have better explanations than I can give you.. I know the how and why but explaining it would just confuse you..at least coming from my fingers.
As for the differences in enclosures there are pros and cons for all of them.
Sealed.. Is generaly very tight and accurate but lacks in the lower frequencies.
Ported is louder and will play lower than a sealed encl. but also isn't as accurate and uses a larger enclosure.
Aperiodic enclosures Use small enclosures like a sealed but with a thin mmbrane that resists the movement of air from the speaker. Most often you need a specific size of the aperiodic material for a given enclosure size...anyway it give you tighter bass than ported but also plays lower than a sealed.
Bandpass enclosures are basically a hybrid.. both ported and sealed simultaneously..They are more sensitive to wattage ( less power to creae the same volume) The downside is that they have a very narrow frequency response..
Anyway hope this helps some..let me know how the report comes out.
Mike
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
951
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
hottieb99
hottieb99
palmdale, ca
Wonderbread
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
