Please help subs not working
  • 2
lowfuel777
CarAudio.com Newbie
I just bought a 2014 equus it has the Lexington surround sound and was trying to hook subs and a amp up in it. Here's what I have I got a box with 2 10s of audio pipe speakers and a 1000 watt amp mtx and a mvx 300watt 2 channel speaker cable to rca adjustable line output converter. This is what I have tried already I tied into the front door speaker wires from the plug that goes into the factory amp that didn't work so I tied into the sub woofer 1 and 2 to the plug that goes into the factory amp. Doesn't work either can some please tell me what to do
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
953
lowfuel777
CarAudio.com Newbie
lowfuel777
Little rock
1aespinoza
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
