Plexiglass help
  • 3
Dafaseles
CarAudio.com Exclusive
402
192
510
So, quick back story....
Helping a friend build/ install a 4th order. It had a decent sized plexiglass window in the front.
We haven't had a chance to get my welder to fabricate up a brace for the enclosure yet. I get a text message today that he's cracked the plexiglass window. It looks like the crack started at one of the mounting bolts. Like any other impatient basshead, he's been slapping it without the enclosure being "done". I don't blame him, I probably couldn't help myself either.
So, we got it from Tap Plastics. It's Chemcast Cast Acrylic. This, or the Ecogreen Recycled Clear Cast Acrylic, where the only styles they offered in ¾" thickness.
My question, is this the right kind of plexiglass to be using in an enclosure? Or did it just crack because of the vibration, and needs to be braced? I just want to make sure it's the right sh*t before we order another sheet.
Rather than plexiglas — use LEXAN it doesn’t crack or shatter…
Here’s some good read up about the differences:
Ok. Makes sense. Thank you!
Now, where to buy lexan near me....🤣 I'm sure I'll find somewhere
This. I have a friend who builds boxes and all he uses is lexan. You could get a big fat 1” thick window in there.
OP, Iirc your window is massive, so it’s gonna flex some, but lexan is what I designed into basically all my boxes with windows, and there’s been zero issues that I know about. The lexan seems to be stronger than even nice birches of the same thickness.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
187
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
553
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
392
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
367
Dafaseles
Dafaseles
Buck
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
